What is the point of lowering 5mm?
Been reading the spec on my ST Line X.
The car has been lowered by 5mm. Really??
Hardly noticeable. What is the point?
Might not just be 5mm their is more to take into account, lower centre of gravity albeit not a lot but it could be a much stiffer suspension.
Yep. It has sports suspension.
Lower suspension helps in a few ways.
Ride height
Centre of gravity
Less roll in bends
Less nose dive under heavy braking
Every little helps.
I've just stopped cars both older ones a 2007 to a 2009 the 07 car had the sports suspension and the newer one had standard the difference is very obvious when driving much less roll on the sport suspension, I dont have any data on the ride heights but the 07 car sat lower when I had them side my side, not much but visually , probably about 8-10 mm
St Line in Ireland is -10mm
Are you sure your one is only 5mm ?
OOPS! 😳 It is 10mm
Still, not a lot 1cm
Same with the Ovtavia vRS
15/18mm ( Not sure which. But to be fair. The Mondeo looks lowered.
The vRS still looks like something on stilts.
