Best Dash Cam For Mk2 Focus????
Proper well done sonic your crimp is also very professional although I ignored that to keep it simple I like that others can put their own twist on it to suit their needs, the mobius is a very flexible cam
  • Replies 134
  • Views 20.3k
  • ok I finally got round to installing the Mobius dash cam and I can say I'm very glad I went with this Cam. it very very Compact and the video quality is superb. I wanted a more compact mounting brack
  • mixmasterlooney
    mixmasterlooney
  • jeebowhite
    jeebowhite
    Its not a case of the best for it, but a case of the best for your needs. There is the Mobius DashCam, the GS8000L (I have this one) And there is the 808 which Byr0n has recently bought:. Click each
any body know how to change the date on this camera
mine sometimes doesnt switch on when i turn the ignition on
post-32857-0-67163900-1408463538_thumb.j
Is that the same camera James has? He would know if so
sent him a pm
Thanks Kurt. Been using the Möbius for a few days now and its great. I'm considering one for the rear window. Also going to experiment with the motion sensor as well. Would be nice to use that when parked up.
That looks like the gs800l camera. James has this cam and I know that there is a glitch somewhere in it that he resets its every now and then I think its when the memory card gets full maybe.
have you got this hardwired in or running of the 12v socket?
its hard wired .ill try a reset see what that does .
No problem you can also upgrade the firmware I think as well on this camera. See how a reset goes first and you may have to go through the on screen settings to set them to your own preferences reset usually reverts back to factory settings.
how can i upgrade firmware ?
I'm not 100% sure myself but a quick google may show you how.
What exactly is your cam doing?
Is it charging and working OK as a standalone camera?
Are you just having these issues when its hardwired in to car?
was is working fine up to a point that any changes or anything was made?
From what James has said about that model of can its seem to be pretty reliable so I would say that any issues your having is probably easy fixed.
