randomly unfortunately... sometimes it sits and swings while travelling steadily... sometimes I think it setlles when booting it, but other times it swings!!
I'm confused as it doesn't seem to have any consistency to it at all
Posted 12 May 2013 - 08:28 PM
Posted 13 May 2013 - 01:59 AM
As it is random/ If its the same as the Mondeo the temp is taken from a sensor on the head, so it is possible that the sensor or the connector going onto it are faulty, (or the wires etc further down the line) the ECU also uses this for cold start so may use more fuel and for detecting overheating so may even go into limp home mode (when the ECU "thinks" the engine is overheating when it is'nt) the other possibility is the temp really is fluctuating as the gauge displays (less likely- but a good reason to have a seperate temp gauge)
I remember reading there was a lot of complaints from some Fords so they "docktored" it to make it read "wrong" but looked "right" (if you know what i mean) i cant believe how cool mine runs on a cold day (ive only recently hooked up my digital temp gauge)
Its under warrantee anyway but im sure you will let us know how you get on
I was on your other forum and i saw a signature of a vax***l with a vented crankcase breather - never actually seen one mentioned before - ive got mine on a long pipe like a secondary exhaust (i dont like talking about other forums or vax***ls though
Posted 13 May 2013 - 09:52 AM
Posted 17 May 2013 - 07:07 PM
Update... Once again the dealer has said a loose connection caused the issue. After a little discussion it has been agreed that if (Dealers terms.. I used "When") it happens again then they will replace the temp sensor...
Latest Comments
More
