You have to configure the interface to MS-CAN mode. It is on the first page of the ELMconfig...
Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
#1336
Posted 15 May 2013 - 10:35 PM
#1337
Posted 15 May 2013 - 10:58 PM
i keep getting this error on both sides of the switch
Check that it's wired correctly and all your solder joints are sound, If they are you should have the HS-CAN working, to get MS-CAN working open ELMconfig, click on ELM327 then Setup ELM327 for MS-CAN bus. I had the same error and it was my soldering had come loose when I put the heat shrink on
#1338
Posted 16 May 2013 - 02:59 AM
Hi, I have a OBDLink MX type bluetooth OBD (based on the STN1170 chip) which can actually be configured to access MS-CAN bus.
I tried using the ELMComfig v2.5 to change the protocol to MS-CAN (STP 51) via the SEND command option but gets a unrecognised response. I am wondering if the response is not recognised by the app. When I do this via hyperterminal, i get a OK.
If anyone can share more about issuing ELM commands via terminal, please advise. I wanted to find out what commands that i need to key in via Hyperterminal. Normally we can see the commands in the Log window of ELMConfig but since I have yet to successfully set the protocol within ELMConfig, I am not able to get the command strings.
What I am trying to accomplish first is to set Autolocking of my Ford Focus MK2.5 car doors when speed reaches 20km/h.
Appreciate your comments. Thanks.
#1339
Posted 16 May 2013 - 11:04 AM
I am looking to disable this particular feature, as its good, but not good enough! I would ideally like to see the doors automatically unlock when the key is removed (as I had on the Cee'd) or when you unlock the drivers door, have it unlock ALL doors.You can achieve this by using the ELM config, you dont need to issue any commands. just switch to the MS bus, and then use the app.
#1340
Posted 16 May 2013 - 11:28 AM
Yeah, the thing is I don't actually have a modified USB ELM327. I have a Obdlink MX bluetooth which is ELM327 compatible and I can set it to MS-CAN protocol. But still can't seem to get it to access the MS-CAN modules. Keeps getting 10 87 CAN error.
#1341
Posted 16 May 2013 - 01:19 PM
I think its a limitation of the hardware, if its not wired fully for these pins then it wont read properly or access all the required area's.
If you had a modified cable, that would work for you.
#1342
Posted 16 May 2013 - 05:07 PM
Ok, finally got MS-CAN working using a bluetooth OBD2 with STN1170 chip !
Here is how you do it.
Pre-Requisites
1. OBDLINK MX Bluetooth or a OBD2 reader with STN1170 chipset that can access MS-CAN protocol
http://www.amazon.co...ords=obdlink mx
2. Latest ELMConfig V2.6
http://civil.iffc.ru...g/ELMConfig.zip
Steps
1. Turn Key to ACC
2. Use a terminal software like hyperterminal or putty to connect via the configured serial COM Port.
3. Once connected and you see ELM327 v1.3, Set OBD protocol to MS-CAN by issuing command "STP 51". It should return OK. Then close terminal session.
4. Launch ELMConfig
5. Set MS-CAN bus in ELM327 Setup page
6. Open Port
7. Click on Read from the GEM module. If it shows you some information instead of N/A means it is able to access MS-CAN modules now.
Hope this helps those who have this OBD2 reader.
#1343
Posted 16 May 2013 - 06:07 PM
Pre-Requisites
Steps
1. Turn Key to ACC
4. Launch ELMConfig
6. Open Port
Cheera fyl , i'm sure that will help others out
#1344
Posted 16 May 2013 - 08:44 PM
Everything its alright now! Thanks
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
