zain611 Posted July 1, 2019 Share Posted July 1, 2019 @D13 HPD 95 looks like you added a ST washer fluid cap 😊. Why did you change the engine cover also from the painted one? Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted July 1, 2019 Author Share Posted July 1, 2019 8 hours ago, zain611 said: @D13 HPD 95 looks like you added a ST washer fluid cap 😊. Why did you change the engine cover also from the painted one? Yh st sticker and a shaved grill for more air flow, and I wanted a stock oem+ look not a showy painted one 🙂 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted July 3, 2019 Author Share Posted July 3, 2019 Front upper strut installed! Running out of mods in the shed to install now 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted July 5, 2019 Share Posted July 5, 2019 Didn't you have a painted engine cover? Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted July 5, 2019 Share Posted July 5, 2019 35 minutes ago, zain611 said: Didn't you have a painted engine cover? He said above he wanted a more stock OEM+ look rather than a showy one 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted July 5, 2019 Share Posted July 5, 2019 24 minutes ago, Jonro2009 said: He said above he wanted a more stock OEM+ look rather than a showy one Sorry I forgot I asked that previously 😅 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted July 6, 2019 Author Share Posted July 6, 2019 Yesss I do 🙂 less showy more oem+ is the look I want added to that the second catch can finally fitted and plumbed in 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted July 20, 2019 Author Share Posted July 20, 2019 Little clean and also removed the vinyl from the doors for more body colour 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted July 21, 2019 Author Share Posted July 21, 2019 An update on what’s going on this next few weeks So done a mini service today, new ITG filter head old one was past a wash an re-oil so new head it is fitted a new pollen filter ( I don’t know how old the last one was but it certainly wasn’t changed in Jan when the last service was carried out 🙄 apparently ) so on the above a mate is helping me fit the R sport baffled sump, with sump plug, new filter and obs an oil change 🙂 to some nice Fuchs Titan pro S 5w30 sweet goodness new plugs to go in as well airtec hotside pipe airtec stage 3 cooler ( so I can fit the airtec oil cooler I cannot with the pro cooler currently fitted ) got myself a cheap set of B8 dampers brand new - so going to get new top mounts and bearing front and rear, and new rear upper spring isolators ( currently have powerflex black series on but they make the rear of the car sit 10mm ish higher than it should and Ford re-released some proper rubber ones not foam so they won’t fall apart ) new front arb drop links adjustable so I can get the front set up currently again If got the cam fuel tappet to change at some point transmission oil to replace fitted the shifter base bushes today makes the changes a lot more precise - I have the transmission bracket ones to do new Cobb rear torque mount with strength plate to install also looking to swop my cobra exhaust for a milltek non res race one annnnnnd getting some 16inch OZ superturismo alloys with ad08r tyres just need a refurb then she’s ready for the oil cooler fitted after next month and the x47r turbo with maxd mapping left to do! Plans hey also house move will be completed within next 5 weeks woop happy happy days 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted July 28, 2019 Author Share Posted July 28, 2019 New set of plates to get on airtec cooler ready for install and last of the red hoses in the engine bay all gone ultra stealthy look now 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted July 29, 2019 Share Posted July 29, 2019 @D13 HPD 95 would you say the plate looks great with or without the border? Just in the process of getting a plate so deciding 😅 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted July 29, 2019 Author Share Posted July 29, 2019 1 hour ago, zain611 said: @D13 HPD 95 would you say the plate looks great with or without the border? Just in the process of getting a plate so deciding 😅 I went for one as I’ve never had the border before so thought why not haha 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted July 30, 2019 Author Share Posted July 30, 2019 New Cobb mount fitted along with a retaining brace to help reduce stress across one bolt and split the stress to multiple bolts decreasing chance of snapping the main mount bolt and also allowing the mount to stay straight and not twist 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted August 10, 2019 Author Share Posted August 10, 2019 New airtec cooler and airtec hot side fitted today 1 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted August 10, 2019 Share Posted August 10, 2019 Definitely a stealthy discreet look going on Quote Link to comment Share on other sites More sharing options...
zain611 Posted August 10, 2019 Share Posted August 10, 2019 I'd love to have it exposed myself but does look like a sleeper. Can I ask how you've attached your plates to the bumper? Just wondering how I should attach my new plates to my car. I bought a discreet plate holder but just want a clean look. Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted August 11, 2019 Author Share Posted August 11, 2019 17 hours ago, Jonro2009 said: Definitely a stealthy discreet look going on Cheers it’s a lot less in your face and not noticeable 15 hours ago, zain611 said: I'd love to have it exposed myself but does look like a sleeper. Can I ask how you've attached your plates to the bumper? Just wondering how I should attach my new plates to my car. I bought a discreet plate holder but just want a clean look. Double sided 3M tape mate holds it perfectly 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted August 11, 2019 Author Share Posted August 11, 2019 Big day today suspension upgrade new B8 dampers new ebiach redline springs new front top strut mounts and bearings new adjustable front drop links new rear spring isolator pads and a summit 4 point lower chassis brace also pics of the airtec hotside car feels like its on rails now, tyres are letting it down round corners so need to figure out if I’m getting new alloys or new tyres also the rear needs an arb to keep the back end flat as it shifts round to much 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted August 14, 2019 Author Share Posted August 14, 2019 New set of PS4’s for the rears due to a puncture and getting close to limit should keep the rear in check more now And bless it hit 66k 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted August 17, 2019 Author Share Posted August 17, 2019 Cheeky buy for myself 🙂 a set of DNA racing light weight front wishbone arms with uniball joints these are meant to last forever these joints due to their unique oil filled joints they don’t rot don’t break and don’t perish over time so hopefully these will outlast the car! Also uniball joints are known for using in racing teams as they give more steering response and feedback than just polybushs also even though polybushs are cheaper and last longer than stock rubber they still diminish and perish over time but are 1/3 of the cost! Mill use polybushs in certain areas where I don’t justify uniball joints, like the rear beam connection Bush, I’ll fit polybushs in them as they are £70 instead of £400 for a set of uniballs and tbh I’m not sure how much more the rear the needs controlling stiffening up after a rear roll bar which is next on the list I think! 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted August 21, 2019 Author Share Posted August 21, 2019 Perks of working away up north for a week, get to check out the local Facebook market place items for sale and notice a seriously cheap milltek non res race cat back exhaust only an hour from your hotel, well it’s rude not to pick it up ain’t it and a cheeky celebration pint 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted August 22, 2019 Author Share Posted August 22, 2019 Another cheeky couple of buys while I was away! Picked up a second hand airtec catch can but no hoses also some new DMB st badges, got a new vision for the car coming soon slick not to in your face but some would call it Fubaru 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted August 23, 2019 Share Posted August 23, 2019 Probably won't be much for the hoses since you got the main thing 👍 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted August 31, 2019 Author Share Posted August 31, 2019 Big day today New gel vent rings from DMB new steering wheel riders thicker and nice alcantara top and bottom with blue stitching and a blue ring (not fitted yet) New ST badges on and removed the Mountune lip finally Picked up some Team Dynamics Proc Race 3 17x7 et 35 so will sit slightly more in the arch than the current wheels these are being refurbed in a nice Subaru gold New PS4 tyres fitted on the front current alloys so matching PS4s on the car now feels lovely and grippy picked up a delta spoiler with carbon blade needs painting in blue though fitted an R-Sport baffle in the sump with a magnetic sump plug here’s the state of the old oil filter which was apparently fitted in January of this year by the state of the oil its been at least 20k miles since it was last changed new powerflex engine mount insert fitted on the drivers side still have passenger gearbox side to do milltek exhiast fitted DNA racing wishbone arms fitted old red coolant hoses removed and stock hoses fitted again so no more leaks, with fresh coolant as well She’s sitting pretty and the drive home was insane! I can not wait to get it aligned correctly as it’s slightly off and get this thing on track now! 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted September 1, 2019 Share Posted September 1, 2019 I think those wheels will look nice in that gold. Your lucky that the oil filter didn't break open otherwise oil would of leaked out and damaged the engine 😬. Need to get my tracking done before MOT. Dad loosened the front joints so the tracking place try not to charge more by saying they struggled to loosen it. In result however the tracking is more off that the steering wheel is facing 30 degrees left when the wheel is facing forward. Quote Link to comment Share on other sites More sharing options...
