Heater cable replacement
Hi Guys,
My heater controls do not change the air outlet direction, only feed is to dash/face louvres. I removed the heater controls (manual aircon model) and could not see the actuator cable which seems to control air direction. Is there a guide or video on this topic? Alternatively, how could I set airflow to a permanent mix of windscreen demist and face louvres manually?
2014 manual aircon model.
I have sourced a new mechanical cable, but it appears this is difficult to install.
  • 3 weeks later...
I have similar problem in that mine works but has become crunchy. To get at the cable on mine I removed the radio. Now you can see the cable and removal although difficult is possible.
You may need to remove the panel with the knobs on.
  • 10 months later...
On 11/22/2020 at 2:23 AM, 2014fiesta said:
I also see that the green aircon bowden cable is missing. Is the any info on where this goes and how to fit it?
So it's taken almost a full year to get back to this problem !!
@frund offered some help back in December 2020, and a 'thank you' might have brought more possible help from others.
