Stiff gear change when cold
Fiesta zetec climate 2007 My gears are stiff even when cold even when the car is off the gearstick is really hard to move  ive drove it for about 5 miles and they where really stiff the car has been parked up for a year but was they was going stiff before that
Most probably the gear oil has reached its service life end or the oil with wrong viscosity is used, I would start by changing the gear oil as @FiestaForever mentioned with the correct specs according to the owner’s manual
  • 8 months later...
A very common problem on the ford fiesta is that the bushing on the gear selector lever gets rusted behind the bushing and pushes it on to the pivot pin. Very easy to fix there's lots of youtube videos that show you how to fix it. I just replaced the gear selector lever instead of drilling or reaming it as suggested on you tube.
