Break servo booster
Hi Ford fans i need help with a break problem on a ST150 have got a soft break pedal if you drive the car hard the pedal is ok ish.. drive the car slow and the pedal sinks about 2" until the breaks work ...want to replace the servo but cant get one new not even ford has got one . I have heard the fusion and puma might be the same ...can anyone help
No. Nothing is wrong with the brakes except the spelling.
I know of a place called Wiltshire in Somerset, but never come across Wilshire.
Wiltshire isn't in Somerset. I think you may be confusing it with Willhire Van Rentals, the Dutch footballer.
living in the North East it's near enough 🤣
Didn't he play for Arsenal ?
Martin, we have all been down the pub!
Yeah, that's the bloke.
Glad you can read a map
I didn’t know Wiltshire is in Somerset, I thought it was next to somerset
Sorry just noticed that’s already been said
It is, being a county but in the frozen Arctic wastes North of Swindon (Wiltshire) they have little use for geography. The huskies usually know where to go and rarely venture near the edge...
Give the chap a break and sort out his brakes...........please
We would if there were anything wrong with them in the first plaice!
Place not plaice whilst you are criticising others. 🙂
What ***** you on about you bell end there is know T in my name   some fat ***** bloke sat on his fat ***** know clue about cars just a ***** taker a ***** that watches you tube vids to fix his car 🍆💦
Thank you for your well considered contribution, Martin. I am sure it will bring a great deal of assistance with your imaginary problem but not your actual one.
pcaouolte You completely missed the point!
All i need to know if brake servo from another model of ford would fit my st150.. as my servo must have a leak i have replaced every thing else and ford have pressure blead the abs system but still keep getting a soft pedal ..or anyone on here know about cars
You didn't make your point very clearly then. You have come across as very rude throughout this thread and have clearly upset the OP when he has made a simple request for help.
If you think that is rude, stick around. This is just very mild sarcasm at the expense of somebody who really is and does not have anything wrong with his car which is working as it should.
Spelling maybe ***** but the brake problem is real when putting your foot on the pedal no brakes until pedal is half way down can you help
Are you losing fluid?
If you drive the car yourself you would not say that
I have had the whole brake system replaced pads discs master cylinder and hoses ..ford have blead the abs system ..but still keep getting a soft pedal
Again, ARE YOU LOSING FLUID?
