1.4 TDCI DuraTorQ Injection/glow plugs loom.
Hi Ceffyn,
Your approach is brilliant to say the least... and you got the issue solved.
I have the same on a 2009 Fiesta 1.4 Duratorq...
Just replaced all 4 injectors with rebuilt ones, so everything should be perfect...
But still have a miss on and off on cyl 3.
I see the rational in rewiring the injectors, but just the injectors.
Which one of the PCM connectors is the one for the injectors? Top, middle or bottom?
Top one seems to go somewhere else, so I think that one is for everything else but the engine itself (dash, warning lights...)
So I suspect the bottom PCM connector is the one with the injector feed wires?
Please can you confirm/correct me?
Thank you,
Jake
On 11/21/2021 at 12:47 PM, YBTURBO said:
That's the layout and pinout of the mk6 injection/glow plug/sensor top loom section. if/when i manage to get a 2nd hand full engine loom i will make diagram's and such of the entire loom.
  • Replies 51
  • Views 35.4k
  • ok so as promised time for an update, got home from work this morning and no delivery of the noid light set 😞 so did i give up and wait, you guessed it nope i got out there and got on a mission s
  • If you get stuck and want me to, I can check local scrap yards near me and post to you, I'm offering because mine was an absolute nightmare to get hold of!
  • final update on this one for now guys, the new injector wiring seems to have sorted it not had an issue since changing it. will be more on this in time when i get to doing the rest of the wiring and t
A little extra information:
The piezo injectors are operated by up to 200 volts, 15 amps. This has the potential to kill and if you manage to disconnect the injector while the piezo crystals are expanding, the crystals will not complete the process and discharge to the ground causing them to remain in their expanded stake, keeping the injector open.
So these injector wires can carry up to 3000 Watt at any given time.
No wonder the loom is very sensitive to any power leaks from damaged wires or cracked insulation.
I wonder if even just the proximity between the wires of the injector inside the rubber loom could cause a spark to jump between them, rather than activating the piezo injector...?
Jake
