Battery replacement, dead modules?
Hello! A couple of days ago I replaced my Ford Focus mk3 battery and I thoughtbthis would be an easy 30min job, but....
After installing it I went to start the car and I got greeted with lot of errors, mainly Engine failure. I hooked up my obd2 cable and opened Forscan to see that the TCM and the PCM can't be accesed, while all the other modules worked properly. Could I have completely bricked the 2 most expensive modules in my car with a simple battery replacement?? No fuses are blown though..
I'd say it's worth contacting Forscan support and sending them the 'bin' and 'txt' files (they'll ask for them anyway) from the forscan log folder (search in windows search bar). They were fantastic when I thought I'd bricked a couple of my modules and very patient with me!!
Does your horn and blower motor work?
Yes, everything works except that the car doesn't know what gear is selected as I can freely change them but none will show up highlighted in the instrument panel and that it doesn't try to crank.
I've hooked up Focccus to it and it can successfully read data from every module except the PCM and TCM, to which it gives me an "Can't read module" error
The only other suggestion I can offer is to check you have battery voltage at F30 in the battery junction box, don't remove the fuse just probe the pins on the top of the fuse either side of the fuse rating.
AFTER CHECKING FUSES
Turn ignition on
leave key in vehicle (if keyless)
open driver's window (in case of accidental lock)
open bonnet
disconnect battery negative for 10 minutes
press brake pedal a few times whilst disconnected
ENSURE positive cable is fully secure
reconnect negative cable
turn ignition off (if key was in ignition still)
start engine without pressing throttle.
See if that works
Turn ignition on
open bonnet
See if that works
Thanks! It didn't work though, I get the same issues as before.. I guess this was done to reset PCM's memory?
That's a great suggestion to check the junction box.. But what do you mean by "at F30"? The 3rd fuse? As they're labeled as MEGA 1...10
That's the high current fusebox with the MEGA fuses.
See attached
Oh you meant the fuse box, my bad. F30 is not used in my car, but I checked visually all the PCM and TCM related fuses and they are not split
I was looking at diagrams for 2013 model, did find a 2014 diagram and equivalent fuse seems to be F38
The fuse is ok sadly..
I'll attach below a short video (30 sec) of what the car does when I try to start it
youtube link
If you haven't already, you really need to contact Forscan support. Forscan wouldn't even find the modules I thought I bricked and the Forscan team wrote new software to resolve the issue. Admittedly, it was different modules, but it's got to be worth a try.
Forscan no longer offers engineering support due to the russian sanctions.. I tried to recover / update the modules with forscan but it didn't work
I guess my best bet is to contact a service with IDS and let them try revive the modules..
Don't try to recover/update the modules.
"Reset" each module in Forscan in maintenance.
Does Forscan see all the modules?
Have you got DTCs?
Also, what adapter are you using? When I bricked my modules, in desperation I plugged my older Tunnelrat adapter to see if it worked, but I had a message come up saying 'using this adapter is not recommended'. Im guessing the newer versions of Forscan dont like the older adapters.
There is also an option in settings, you might want to try. Change the 'ISO 17565' support from 'Auto' to 'application'.
I'm not 100% sure what this does, but this is what Forscan support advised me to do. As you are not getting a response from them....its worth a try!!
That's a generic warning they give now, in case you try to do updates with it. They're OK for DTCs and programming etc
Have you got DTCs?
I got DTCs in all the modules, mainly "can't connect to ecu" or "can't connect to tcm", but the DTCs in the tcm and pcm can't be read.
I have their reccomended OBDLink EX. I'll try that
Just another thought..... have you tried connecting to the vehicle without using the stored profile?
Have you had it remapped?
yes and it fails
what exactly?
forgive the obvious but.. why did you replace the battery and which battery have you replaced it with?
what exactly?
Have you had the car remapped?
