slimsimmons1984 Posted March 29, 2022 Share Posted March 29, 2022 hey guys timinig belt snapped on the motorway earlier this week聽馃サ anyone had a similar experience and have an idea of damage/rebuild cost? 聽 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 29, 2022 Share Posted March 29, 2022 Can you remove the top cam cover so we can see if any damage has occurred in there?聽 Being 8v might have saved the valves themselves so it may not be a huge repair job. However, it's a very common engine and we don't see many engine failures from belts snapping so it's probably cheaper and easier to fit a used engine rather than repair it. Quote Link to comment Share on other sites More sharing options...
unofix Posted March 29, 2022 Share Posted March 29, 2022 Don't even think about trying to rebuild it. The cost and time to do it will just be beyond economical repair. Just source a secondhand engine from a scrapyard Quote Link to comment Share on other sites More sharing options...
slimsimmons1984 Posted March 29, 2022 Author Share Posted March 29, 2022 belt was changed last year by previous owner, so im guessing something has gone wrong with whatever they fitted (not through a garage) gutted as ive only had the car 4 weeks 聽 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 29, 2022 Share Posted March 29, 2022 5 minutes ago, slimsimmons1984 said: belt was changed last year by previous owner, so im guessing something has gone wrong with whatever they fitted (not through a garage) gutted as ive only had the car 4 weeks The DV6 belt is a very simple one, there's not much they could have got wrong!聽 Could you check if the crank pulley is still in place?聽 If there's coolant leaking from the waterpump area?聽 And as above, can you remove the top cam cover?聽 Those things would give us a better idea of what may have failed and what may need repair. Quote Link to comment Share on other sites More sharing options...
slimsimmons1984 Posted March 29, 2022 Author Share Posted March 29, 2022 27 minutes ago, TomsFocus said: The DV6 belt is a very simple one, there's not much they could have got wrong!聽 Could you check if the crank pulley is still in place?聽 If there's coolant leaking from the waterpump area?聽 And as above, can you remove the top cam cover?聽 Those things would give us a better idea of what may have failed and what may need repair. at the moment ive pulled the top belt cover back and spotted theres no belt left we did find a bolt when it was being dropped off the lowloader so my guess is a pulley has come off havent had a chance to look into the rest yet, but im guessing with the belt coming off at 70/80mph theres considerable damage Quote Link to comment Share on other sites More sharing options...
slimsimmons1984 Posted March 29, 2022 Author Share Posted March 29, 2022 one other quick question, any idea where the engine code is placed so i can find a matching engine? Quote Link to comment Share on other sites More sharing options...
Focus_ Posted March 29, 2022 Share Posted March 29, 2022 3 hours ago, unofix said: Don't even think about trying to rebuild it. The cost and time to do it will just be beyond economical repair. Just source a secondhand engine from a scrapyard ...and get the belt replaced on that one before putting it in the car 馃槈 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 29, 2022 Share Posted March 29, 2022 1 hour ago, Focus_ said: ...and get the belt replaced on that one before putting it in the car 馃槈 Belts rarely fail on these.聽 In this case it looks like replacing the belt was the cause of the failure! 聽 3 hours ago, slimsimmons1984 said: one other quick question, any idea where the engine code is placed so i can find a matching engine? It should be a DV6C.聽 Engine code was originally on a sticker on the cambelt cover...but that's probably faded or fallen off by now.聽 Block etching could be on the front edge just behind the alternator, or around the oil filter/cooler.聽 Either way, not easy to see with ancillaries fitted.聽 Your V5 logbook may also contain an engine code.聽 That's likely to be a Ford specific 4 digit code that can then be used to find the generic PSA/FMC engine number. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 29, 2022 Share Posted March 29, 2022 You can probably get all the build details of your vehicle if you enter your reg number in to the Ford ETIS system. https://www.etis.ford.com/ https://www.etis.ford.com/vehicleRegSelector.do Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 29, 2022 Share Posted March 29, 2022 Full engine code doesn't show on ETIS.聽 Will just say DV6. 1 Quote Link to comment Share on other sites More sharing options...
Focus_ Posted March 29, 2022 Share Posted March 29, 2022 8 hours ago, TomsFocus said: Belts rarely fail on these.聽 In this case it looks like replacing the belt was the cause of the failure! Well that is true 馃槅 Quote Link to comment Share on other sites More sharing options...
Nathan Buffery Posted March 30, 2022 Share Posted March 30, 2022 Just out of interest, what needs to be changed/ modified in terms of the onboard electronics when swapping an engine? And can all of it be done by Forscan?聽 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 30, 2022 Share Posted March 30, 2022 If you swap the engine like for like, and keep all the original modules belonging to your vehicle then there is very little that needs to be programmed/updated. Any changes that maybe needed will be able to be done by FORScan and a decent ELM327 lead or better the new vLinker FS cable. 1 Quote Link to comment Share on other sites More sharing options...
slimsimmons1984 Posted March 30, 2022 Author Share Posted March 30, 2022 2 hours ago, unofix said: If you swap the engine like for like, and keep all the original modules belonging to your vehicle then there is very little that needs to be programmed/updated. Any changes that maybe needed will be able to be done by FORScan and a decent ELM327 lead or better the new vLinker FS cable. i was just about to ask the same question as when i chaged my mk1 focus diesel i had to keep the solenoid or something similair off original pump ive just ordered a cable to use with forscan Quote Link to comment Share on other sites More sharing options...
slimsimmons1984 Posted March 30, 2022 Author Share Posted March 30, 2022 these are the stickers on side of engine Quote Link to comment Share on other sites More sharing options...
slimsimmons1984 Posted March 30, 2022 Author Share Posted March 30, 2022 22 hours ago, Focus_ said: ...and get the belt replaced on that one before putting it in the car 馃槈 replacing the belt is what killed this one off聽馃槃聽gates kit with waterpump belt etc typical my luck lol Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 30, 2022 Share Posted March 30, 2022 31 minutes ago, slimsimmons1984 said: these are the stickers on side of engine T1DB is the Ford engine code.聽 DV6C is the engine family (also used in Peugeot, Citroen, etc.)聽 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 30, 2022 Share Posted March 30, 2022 22 hours ago, TomsFocus said: It should be a DV6C.聽 Engine code was originally on a sticker on the cambelt cover. I see you were 100% correct Tom, it is indeed a DV6C 馃憤 1 Quote Link to comment Share on other sites More sharing options...
slimsimmons1984 Posted March 30, 2022 Author Share Posted March 30, 2022 is there any difference in the citroen engines? just changed a gearbox on my ds3 with same engine code Quote Link to comment Share on other sites More sharing options...
unofix Posted March 30, 2022 Share Posted March 30, 2022 2 minutes ago, slimsimmons1984 said: is there any difference in the citroen engines? Yes, the ECU speaks French 馃ぃ 1 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 30, 2022 Share Posted March 30, 2022 34 minutes ago, slimsimmons1984 said: is there any difference in the citroen engines? just changed a gearbox on my ds3 with same engine code The main engine block/head is the same as long as both are DV6C.聽 But the ancillaries may be different. Quote Link to comment Share on other sites More sharing options...
slimsimmons1984 Posted April 1, 2022 Author Share Posted April 1, 2022 On 3/30/2022 at 1:56 PM, TomsFocus said: The main engine block/head is the same as long as both are DV6C.聽 But the ancillaries may be different. the pug/cit advertised engines seem to be cheaper than specific ford advertised, had no luck finding anything local so far Quote Link to comment Share on other sites More sharing options...
slimsimmons1984 Posted April 8, 2022 Author Share Posted April 8, 2022 On 3/29/2022 at 10:54 AM, TomsFocus said: The DV6 belt is a very simple one, there's not much they could have got wrong!聽 Could you check if the crank pulley is still in place?聽 If there's coolant leaking from the waterpump area?聽 And as above, can you remove the top cam cover?聽 Those things would give us a better idea of what may have failed and what may need repair. wouldn't happen to know if there's a guide for locking engine and changing belt etc? I've tried searching but no luck Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 8, 2022 Share Posted April 8, 2022 3 minutes ago, slimsimmons1984 said: wouldn't happen to know if there's a guide for locking engine and changing belt etc? I've tried searching but no luck I made a guide for the older 16v model a few years ago.聽 The second cam on those was driven by a chain so the belt change is basically the same on both engines.聽聽 Basic Cambelt Change Guide - Mk2.5 Focus 1.6 TDCi - Ford Focus Club - Ford Owners Club - Ford Forums 聽 Quote Link to comment Share on other sites More sharing options...
