Airbag light.
Hi all, anyone throw light to my problem. The airbag light on the dash flashes three times at intervals, what is going on please? Cheers.
Sounds like airbag fault, but usually disconnecting the plug and reconnecting a few times will sort it. Make sure you have the radio code and then disconnect the battery first, wait 15-20 mins and then try disconnect/reconnect plug.
This should help you identify which airbag it is.
Thank you David. I will look into it.
