T T Posted April 9, 2022 Share Posted April 9, 2022 Does anyone know the location of the ignition module on a MK3 XR3i? Quote Link to comment Share on other sites More sharing options...
isetta Posted April 9, 2022 Share Posted April 9, 2022 Don’t know about xr3i but when I had mk3 1.6ghia I am pretty sure the ignition module was screwed to the side of the distributor. Most people I know who had mk3 escort had electronic ignition problems. The failure rate was high. I don’t know if it was different when the i came out. If it has separate unit and it’s not mounted on distributor I think it will be on near side inner wing. Follow wires from distributor and Ignition coil. Does xr3i have a distributor? I don’t know how much more advanced the i was Quote Link to comment Share on other sites More sharing options...
isetta Posted April 9, 2022 Share Posted April 9, 2022 More on above. I might be wrong but I think when the units mounted on distributor failed, the replacement may have been new distributor and separate electronic unit on the wing. I wonder if failure might have been the heat as dustributor would have been quite hot and transmit the heat to the electronic module. Edit: can’t find evidence of that, perhaps I imagined it. Quote Link to comment Share on other sites More sharing options...
isetta Posted April 9, 2022 Share Posted April 9, 2022 See pic. https://www.ebay.co.uk/itm/185315575378?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338268676&toolid=10044&customid=EAIaIQobChMIsMv-l5uH9wIVFpftCh1H9AcREAQYASABEgI0yPD_BwE The black bit is the electronic ignition module I think. That must get a lot of heat. Quote Link to comment Share on other sites More sharing options...
