L05tB0y Posted July 21, 2022 Share Posted July 21, 2022 Hi all, I think I've managed to source some alloy wheels off a custom for my M7 and they come with nuts. I've been told the Custom nuts are different to the Mk7 , my question is can I use my original nuts or will I have to buy some specific ones. Thanks Dave Quote Link to comment Share on other sites More sharing options...
Guest Posted July 23, 2022 Share Posted July 23, 2022 This depends on if the wheels are stock or aftermarket as most after market wheels have slightly larger lug holes as to allow a verity of lug sizes which utilize the same bolt pattern. You need to check your van's bolt size IE M12 or M14 etc to see what lugs are needed. But as I said the aftermarket wheels would need a larger or flanged/budge lug size for these aftermarket wheels. Quote Link to comment Share on other sites More sharing options...
L05tB0y Posted July 25, 2022 Author Share Posted July 25, 2022 Apparently their M14 x2 but I think I need alloy nuts for the alloy wheels Quote Link to comment Share on other sites More sharing options...
Guest Posted July 25, 2022 Share Posted July 25, 2022 If your van utilizes the 5x160 then it needs the M14 - 1.5 lugs If your van utilizes the 6x180 then it needs the M14 -2.0 lugs as you've stated. In other words, if your van has 5 lugs per wheel then you need the M14 -1.5. If your van has the 6 lug pattern, then you'll need the M14-2.0 lugs. Quote Link to comment Share on other sites More sharing options...
L05tB0y Posted July 26, 2022 Author Share Posted July 26, 2022 It's 5 nut pattern but I was sure I read they were M14x2 Quote Link to comment Share on other sites More sharing options...
