MK7 misfire
Hello,
Got an issue with a 2011 Fiesta MK7 1.2 Petrol. It was purchased after being in an accident. Front end has been repaired but engine has misfire.
I have renewed:
Spark plugs, leads, coil pack and still the misfire exists.
I have pressure tested the cylinders
Cylinder 1 is 165
Cylinder 2 is 160
Cylinder 3 is 200
Cylinder 4 is 150
The only thing I can think of next is the throttle body. Anyone have any further suggestions on what it could be?
Also note the engine light was on when car arrived and it was the MAP Sensor which was replaced.
Have you monitored the engine using FORScan ?
Do all cylinders misfire or is it only one ?
  • 7 months later...
Has your fault been fixed , I'd be interested to hear how ?.I have similar fault same type car. It only miss fires on cylinder 3.
So would I, but @RMVS would unfortunately seem to be a One Post Wonder.
Get codes read, it will tell you which cylinder is miss-firing
