fordowner1738 Posted August 26, 2022 Share Posted August 26, 2022 Hello ladies and gents, I made this thread so that hopefully someone with a bit more knowledge than me could help identify the problem I am having with my Ford Fiesta. It is a 1.25 litre MK7 2011 plate. Whilst driving it today, I received a message saying something along the lines of 'Engine oil Pressure Low, Stop Safely'. I was wondering that the problem could possibly be. I have checked my engine oil levels and there is enough oil as I put some in the other day. The engine has become very hot and I have white smoke coming out of the oil filler cap with a tyre-like burning smell. I have looked online and on Youtube and some videos suggest that the problem could be with the oil pressure sending unit/switch. I have tried to look for the location of this switch/unit under the hood but cant seem to find. My plan was to find it and replace and then see if that fixes it. If not, I would just take it to the mechanic. Has anyone else had a similar problem with the Fiesta? Also does anyone know where exactly this switch/unit is as I cant seem to find it online anywhere. Thank you for the help in advance! Quote Link to comment Share on other sites More sharing options...
unofix Posted August 26, 2022 Share Posted August 26, 2022 ..and did you Stop ? Have you considered that the pressure sender may be correct and that you have no oil pressure ? 1 Quote Link to comment Share on other sites More sharing options...
fordowner1738 Posted August 26, 2022 Author Share Posted August 26, 2022 Yes I did stop. Sorry I am pretty much a novice when it comes to cars and the mechanics behind it. How does one go about checking the no oil pressure you have mentioned? Quote Link to comment Share on other sites More sharing options...
unofix Posted August 26, 2022 Share Posted August 26, 2022 I would recommend contacting a garage and getting them to collect it. If you have little or no oil pressure then starting the engine will cause major damage. Quote Link to comment Share on other sites More sharing options...
fordowner1738 Posted August 26, 2022 Author Share Posted August 26, 2022 Okay, my mechanic isn't too far from me so will take it to him tomorrow. Appreciate the help! Quote Link to comment Share on other sites More sharing options...
OvEr_KiLL Posted August 27, 2022 Share Posted August 27, 2022 19 hours ago, unofix said: I would recommend contacting a garage and getting them to collect it. If you have little or no oil pressure then starting the engine will cause major damage. 18 hours ago, fordowner1738 said: Okay, my mechanic isn't too far from me so will take it to him tomorrow. Appreciate the help! do what unofix recommended, get him to come and look at it before you start it! 2 Quote Link to comment Share on other sites More sharing options...
agraham Posted August 27, 2022 Share Posted August 27, 2022 20 hours ago, fordowner1738 said: The engine has become very hot and I have white smoke coming out of the oil filler cap with a tyre-like burning smell. I'm afraid that sounds rather ominous 😞 Perhaps a classic wet cam belt degradation debris blocking the oil pump issue. Quote Link to comment Share on other sites More sharing options...
isetta Posted August 27, 2022 Share Posted August 27, 2022 He said it’s a 1.25, they are traditional dry belt. I have had two cars that had no oil pressure. Triumph TR7 - spring broke in pressure relief valve. Ford Granada 3.0 v6, hexagonal oil pump drive shaft wore down to circular so it did not turn the pump. I do not now what these parts are like on that 1.25 engine. On my brothers Audi TT low oil pressure was down to blocked oil filter ( the oil filter you change, not the strainer mesh) Quote Link to comment Share on other sites More sharing options...
agraham Posted August 28, 2022 Share Posted August 28, 2022 13 hours ago, isetta said: He said it’s a 1.25, they are traditional dry belt. My bad. I totally misread it, thinking it was a 125hp Ecoboost which I am currently primed to recognise 😞 1 Quote Link to comment Share on other sites More sharing options...
