mrdford Posted September 10, 2022 Share Posted September 10, 2022 Hi all, When I lock from the driver side, I hear it lock, but then unlock again immediately. It works fine from the passenger side though. Unclipping the electronic connector inside the driver door makes it lock itself OK. So that's my current temporary measure. (Lock other doors from inside via pushing the passenger handle in, then locking drivers side with the key). Any help to debugging this issue greatly appreciated! 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted September 10, 2022 Share Posted September 10, 2022 The little microswitch inside the drivers side door lock is not working. Either the switch has broke or the wiring to the switch has broken. The central locking system is not able to detect that the drivers door is closed and so it unlocks the doors after you lock them. On your model I'm not sure where the microswitch is located, but on most Ford models the switch is inside the door latch. You will have to take the door card off and have a look at the door latch and see if there is wires connected (normally two or possible three). Spraying lots and lots of WD40 inside the door latch sometimes fixes the problem. 2 Quote Link to comment Share on other sites More sharing options...
mrdford Posted September 10, 2022 Author Share Posted September 10, 2022 Thanks, I'll have a look now when I remove the door card again this weekend. Although, as a quick experiment, I tried locking from the passenger side with the passenger door open, and I get no sound of attenuators (ie. it doesn't do the lock/unlock thing). So would that not be the same expected behaviour if the driver side switch was showing the door as open? ie. it wouldn't make any sound at all? Quote Link to comment Share on other sites More sharing options...
mrdford Posted September 10, 2022 Author Share Posted September 10, 2022 Here's a video of the behaviour: https://streamable.com/3lpu1u As you can see, it does it both locking, and unlocking. It's like one of those "useless box" machines! Quote Link to comment Share on other sites More sharing options...
Dan62 Posted September 11, 2022 Share Posted September 11, 2022 From your description and video I would say the front passenger door lock MOTOR has failed. Quote Link to comment Share on other sites More sharing options...
YBTURBO Posted September 11, 2022 Share Posted September 11, 2022 my 2007 fiesta randomly does the same, on mine i know its the micro switch in the passenger door. spraying it with electrical cleaner sorted it for a while but its still intermittent. when it happens the "door open" light shows on the dash with ignition on, when that shows i lean over and open and close the door a few times until the light finally go's out then i get out and it will lock fine. been considering working out where the wires run and disabling it by giving it a perm open or perm closed circuit depending how it operates but its a minor thing so on hold while i sort more important things on the car 🙂 Quote Link to comment Share on other sites More sharing options...
