TerryS Posted September 27, 2022 Share Posted September 27, 2022 Hi all,downloaded Forscan all good,put cd in for adaptor,adaptor connected to forscan,but error,unable to connect to car turn ignition on,have tried everything,but nothing seems to work,any ideas would be appreciated Quote Link to comment Share on other sites More sharing options...
unofix Posted September 27, 2022 Share Posted September 27, 2022 What make of cable are you using ? Quote Link to comment Share on other sites More sharing options...
TerryS Posted September 28, 2022 Author Share Posted September 28, 2022 Quote Link to comment Share on other sites More sharing options...
Frembrit Posted September 28, 2022 Share Posted September 28, 2022 Probably the cable...I have a Tunnelrat version (which used to be the go to cable) but now Forscan are recommending Vgate vLinker cables. I recently had to reinstall an older version of Forscan to get my cable to work. My friend bought the Vgate cable and that works so much faster than my Tunnelrat cable, so I'll be getting one of those soon. Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted September 28, 2022 Share Posted September 28, 2022 Try flicking the switch and connecting again. Have you installed the drivers correctly Quote Link to comment Share on other sites More sharing options...
TerryS Posted September 28, 2022 Author Share Posted September 28, 2022 Tried all that,going to try later on a more updated laptop Quote Link to comment Share on other sites More sharing options...
unofix Posted September 28, 2022 Share Posted September 28, 2022 FORScan works well with Windows 7 It probably works with Windows 10 but I've not tried it. Have you changed the setting in FORScan from 'Demo Mode' to 'Debug Mode' ? Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted September 28, 2022 Share Posted September 28, 2022 32 minutes ago, unofix said: It probably works with Windows 10 but I've not tried it. Perfect on 10 Quote Link to comment Share on other sites More sharing options...
TerryS Posted September 28, 2022 Author Share Posted September 28, 2022 35 minutes ago, unofix said: FORScan works well with Windows 7 It probably works with Windows 10 but I've not tried it. Have you changed the setting in FORScan from 'Demo Mode' to 'Debug Mode' ? Yes,its in debug mode. Just not connecting to car,probably something simple,as I said will probably try a more up to date laptop. The adaptor I got, there were no instructions just a CD in with adaptor Quote Link to comment Share on other sites More sharing options...
Frembrit Posted September 28, 2022 Share Posted September 28, 2022 WIll be worth trying older versions of Forscan too. As I mentioned, my cable would not work with the latest version of Forscan, but installing an older version (which I knew that worked previously) allowed it to work. Old versions here 1 Quote Link to comment Share on other sites More sharing options...
Jimpster Posted September 28, 2022 Share Posted September 28, 2022 Also try installing Runtime its neccesary even with FORscan and helps with laptop/cable comms. usually available on the jamessimpson.com site Quote Link to comment Share on other sites More sharing options...
TerryS Posted September 28, 2022 Author Share Posted September 28, 2022 1 hour ago, Frembrit said: WIll be worth trying older versions of Forscan too. As I mentioned, my cable would not work with the latest version of Forscan, but installing an older version (which I knew that worked previously) allowed it to work. Old versions here Thanks,what version would you suggest ? Car is 2014 Focus Zetec S Quote Link to comment Share on other sites More sharing options...
Jimpster Posted September 28, 2022 Share Posted September 28, 2022 Go 1 back 2.3.47 wont hurt as its free try and if not joy go 2.3.45, remember to also add runtime when installing, and for some features you will need the extended licence. Quote Link to comment Share on other sites More sharing options...
TerryS Posted September 28, 2022 Author Share Posted September 28, 2022 7 minutes ago, Jimpster said: Go 1 back 2.3.47 wont hurt as its free try and if not joy go 2.3.45, remember to also add runtime when installing, and for some features you will need the extended licence. Will try later,only want to diagnose a problem that isnt showing up on a basic obd2 scanner,do not want to change any features,trying to save myself £95 from Ford 1 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted September 28, 2022 Share Posted September 28, 2022 24 minutes ago, TerryS said: Will try later,only want to diagnose a problem that isnt showing up on a basic obd2 scanner,do not want to change any features,trying to save myself £95 from Ford Go on the Forscan forum and read the posts about connection settings, it's probably something daft 1 Quote Link to comment Share on other sites More sharing options...
Frembrit Posted September 28, 2022 Share Posted September 28, 2022 1 hour ago, TerryS said: Thanks,what version would you suggest ? Car is 2014 Focus Zetec S I can't remember and not anywhere near my laptop currently but it was quite a few versions back, maybe one in 2020. Quote Link to comment Share on other sites More sharing options...
TerryS Posted September 28, 2022 Author Share Posted September 28, 2022 I give up,off to Ford I think, tried everything now Quote Link to comment Share on other sites More sharing options...
Tizer Posted September 28, 2022 Share Posted September 28, 2022 You should get your money back for that adaptor. FORScan don't make adaptors and the only four named ones that they recommend on their download page don't call themselves FORScan adaptors, any that do are likely to be poor quality clones. 6 Quote Link to comment Share on other sites More sharing options...
VFR800 Posted September 29, 2022 Share Posted September 29, 2022 On 9/27/2022 at 9:43 PM, TerryS said: Hi all,downloaded Forscan all good,put cd in for adaptor,adaptor connected to forscan,but error,unable to connect to car turn ignition on,have tried everything,but nothing seems to work,any ideas would be appreciated https://www.bmdiag.co.uk/forscan-diagnostic-cable-for-ford-vgate-vlinker-fs Tried and tested. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted September 29, 2022 Share Posted September 29, 2022 5 minutes ago, VFR800 said: Tried and tested. Very true - but also out of stock 🤣 Most places are out of stock just now, even the ones who say "in stock" and then quote 14 days delivery. Quote Link to comment Share on other sites More sharing options...
TerryS Posted September 29, 2022 Author Share Posted September 29, 2022 6 hours ago, unofix said: Very true - but also out of stock 🤣 Most places are out of stock just now, even the ones who say "in stock" and then quote 14 days delivery. I have given up,sent adaptor back to seller,booked into Ford next week Quote Link to comment Share on other sites More sharing options...
Jimpster Posted September 29, 2022 Share Posted September 29, 2022 Maybe someone near you has what you need, anyone can borrow my FORscan if they just ask. Quote Link to comment Share on other sites More sharing options...
TerryS Posted October 3, 2022 Author Share Posted October 3, 2022 On 9/29/2022 at 6:37 PM, Jimpster said: Maybe someone near you has what you need, anyone can borrow my FORscan if they just ask. All sorted,ordered another cable,connected straightaway,so dodgy cable to start with and got a refund,so good result,thanks for help 2 Quote Link to comment Share on other sites More sharing options...
Kelvin Jay Posted November 9, 2022 Share Posted November 9, 2022 Ive had the same issue before and i fixed by finding the right driver..the only solution is the driver..just go to device manager and check in COM if it says driver is old you need to find the driver. Quote Link to comment Share on other sites More sharing options...
