£600 Auto Oil Change?
Just been quoted £600 for an Auto Gearbox Oil change from a local Ford Dealer for my 2005 Focus. I said why so expensive he said the Oil would cost £180 and the rest would be three hours time. Is this normal? And just to say if your a nasty contributor like oh i suppose you want them to do it for free or well what do you expect your cars really old or why dont you change your car etc please DONT reply- Im not looking for judgement there seems to be ALOT on this Forum im just looking for advice re Price THATS ALL  Also RIP Ken Block
I was quoted £400 by a Ford dealer last year for a Powershift gearbox, but I don't think yours is! I reckon they have quoted for a powershift gearbox without checking properly.
So it should be way cheaper than that - I'd guess around £150 ....Unless I'm missing something???
£388.00 Ford main dealer Newcastle
Makes you really appreciate Wheeler Dealers where Edd/Ant/Elvis just change auto box oil without a 2nd thought and make it look so easy...
Blimey, I don't know whether to respond or not??
But £600 is way too much
The transmission on your car has no drain plug, so you have to remove the sump.
But you have to remove the sump to get to the filter anyway.
You could do it your self, if you can raise all four corners of the car equally, as it needs to be level but off the ground enough for you to get under.
Then buy a filter, the correct amount of the correct fluid and a sump gasket, remove the sump and the fluid, change the filter, refit the sump and fill back up. That should cost you around £50-100 depending on how much the fluid costs.
To do a real quick job, you could get a tube pump and suck the fluid out from the level check hole and just replace what you took out, then check level and top up, that will cost you the hire of the pump, plus fluid.
Or you can remove the transmission cooler feed pipe from the rad pack (or cooler, whichever you have), start the engine and run until the fluid stops coming out, then replace what came out and top up using the level hole.
If you do it your self, the car must be level and the fluid must be warm, replace what you took out, then drive the car for about five minutes to get into every gear and the fluid warm, level the car again and check level and top up as necessary.
I hope I wasn't too nasty
What Mileage would you change gearbox powershift oil ?
Why ? " unless under warranty" would anyone use Ford services at such extortionate rates. Find a Mechanic you can trust and stick with them. THe fluid change on my last 1.6 auto cost £200, oild and labour. My current is due a change and service as altho low mileage it still has time as a factor.
Ford say sealed for life, Guru's say 40,000+
Wet clutch (diesels) 3yrs 36,000
Dry Clutch (Petrols) not sure but 3yrs won't hurt, the oil doesn't get as contaminated in the dry clutch cars, but I'd still change it anyway
Thanks for Replys I thought the Price was crazy I think ill look into doing it myself thanks for Instructions DaveT70 I would normally NEVER go to a Dealer for any work but i went to two local mechanics and one said if we change the oil at this stage it could do more harm than good because of high mileage(115000) etc the other mechanic said its a real tricky job and if there are any problems its too late when in the middle of the job to fix and the car might be rendered a right off? Also i think everyone was very nice no nastiness at all so most likely i over reacted  🙂
The most important thing about doing it yourself is to be indoors where there is no dust nor air currents to blow any dust about. Autobox work needs to be as clean as brain surgery. If it is, you'll be fine. If not then you won't.
Clean the pan scrupulously and use lint free wipes to clean everything. It isn't hard and it isn't expensive. Good luck.
If todays mechs cant plug it in then bolt on a new bit their stuffed, suck air thru teeth shake head and say nah mate. 115000 is nothing on todays engines if looked after, the one that said its tricky has never looked at the google how to's. THats a very broad generalisation but valid, apologies to younger mechs that do it properly.
Ford say 37500 miles or 3 years.
A strong word of caution needs to be added here - raising the entire vehicle off the ground comes with much greater risk of a serious accident than just raising one end.
However, for this job, raising the whole vehicle isn't actually necessary. If my Haynes manual is the correct one, and I believe it should be, your transmission will have a dipstick for checking the level, rather than the fill/level plug that mine has, and the Haynes manual instructs to fill the transmission via this dipstick tube. This means that you can do the refilling on level ground without the vehicle raised at all, you only need to temporarily raise the front to take the fluid pan off to remove the old fluid and change the filter, then you can put it back on (with a fresh gasket) and lower the vehicle again before proceeding to refill. This will be much easier and safer than getting the entire vehicle raised.
On the North American Focus that may well be true, but not I suspect on a UK/European model.
Hmm. You may well be right, but this seems to me like too big a mistake for Haynes to have made, no?; they even include a picture. 🤔
I'm not doubting your information, but I've owned automatics for 30 years and I've yet to have one that the oil level can be checked on.
Ford Europe always claim the gearbox is sealed for life, but in North America the same car with the same gearbox will have an oil change service interval.
Sure, I understand and I respect that you have far more experience than I do. Just to clarify, the Haynes instructions I'm reading do correctly seem to be based upon the European 'sealed for life' concept. For both autos and manuals, they don't speak of renewing the fluid, only checking the level every so often, and they do not provide a specific section on how to perform a fluid renewal. The section on checking the level says that auto models have a dipstick, and they include a picture of it, and then the section within the auto-transmission chapter on how to remove the fluid pan, which they note is only provided wrt. fixing any leak, instructs to use said dipstick to refill upon refitting. So unless Haynes have screwed up big time, this must be a rare case where Ford actually provided us with a dipstick. 😕
Haynes manual (covering petrol 54-61 registrations) states that an automatic transmission has a volume of 6.7 litres of transmission fluid, to Ford spec WSS-M2C938-A.
A quick google suggests that purchasing it may cost something like around £12-15 per litre, so very roughly around £84-105 to fully renew.
What? With axle stands? I doubt it
Shop around, I used Onbuy and got a good deal on mine
On autos, vehicle needs to be level, to get the fluid out and fluid needs to be warm
Vehicle needs to be level, to check level and fluid needs to be warm.
Ensure you drive vehicle before you check level, so that it runs through gears, then check (replace what you took out) you won't get all of it out as about 2 litres stays in the torque convertor. As you are at 115,000 miles the fluid will be quite dirty and, as you will only drain about 50%, budget/plan on running for about another 3,000 miles and doing it again
If there's no dipstick there will be a level check plug on the side of the casing somewhere, mine is in the LHF wheel arch, you have to take the wheel off and level the car back up
So he'll be lucky to get 4 litres out
It's just normal, run of the mill, semi-synthetic ATF in those boxes so won't be expensive if he shops around
Woow ......Wish i'd never asked . Frightened or what  ☹️
Nah lol, depends how competent you are, if putting on axle stands put something under the car so if the relatively impossible happens you may be injured but no squashed and killed, There are deals to be had on Fluid and also on filter and gasket kits. There are even some garages will rent you a ramp for a few hours, and generally have a competent mech on hand should they be needed.
