12v alternator replaced with 14v alternator... help.
Just now, Thee Weeder said:
Greetings... the error codes seem to have stopped but the high readings remain .
Car starts ok , drives ok ...
Thanks .
Thanks .
On 4/30/2023 at 7:12 PM, RL123 said:
As far as the alternator is concerned, I wonder if the 14v is a smart alternator for the stop/start vehicles and requires a battery monitor control to regulate the voltage which yours does not have.
not sure but worth considering
Greetings RL123 ...
The 14v post I did , was based on someone's opinion . He was wrong...
I have sense found the specs sheet of the new alternator and it's a 12v.
The high readings on the battery still the same , the car starts and works ok . The warning lights are gone ( took the car for a small test drive ) and everything works ok ...
Thanks for the help ...
On 4/30/2023 at 7:16 PM, Thee Weeder said:
No stop/start button . its a 2009 Focus CC
Which engine is yours as this alternator (Part number : 401591731) is not compatible with 1.6 Petrol or 2.0 Diesel according to Eurocarparts check. (Hoping you have 2.0 Petrol)
