Another Clutch Pressure problem
Hello fellow Fiesta owners,
Just  purchased a 2017 Fiesta (second hand) all seemed fine for a couple of weeks then sudden started to experience a strange clutch issue. After driving about 15-20 minutes the clutch pressure drops to zero the peddle goes to the metal and obviously you can change gear. By Stopping the car, turning off the ignition and putting in to neutral and restarting the pressures back for a while then we restart the cycle. Plenty of fluid in the system no leaks etc.
From the forums I see plenty of similar clutch pressure problems but no really solutions does anyone have any suggestions or had the same experience?
Beginning to think I’ve been sold a pup but the cars otherwise great!
frustrated Yorkshire
Without checking personally..it could be the master or slave cylinder (either seals or lack or fluid)
Dan
Dan
? weak pressure plate fins maybe (getting warm & softening but hardening once cooled??) "Stab in the Dark!"
