Mk7 ground location
Hi everyone
Just wondering if anyone can help, I’ve been looking for a place to ground a dashcam in my mk7 fiesta for ages and haven’t seen anything around the passenger side fusebox.
Does anybody know where the ground bolt is/if there is one? 64 plate 1.5tdci if that’s any use.
Thanks 😄
It doesn't have to be a bolt that's already got a ground wire.  Any bolt on the metal chassis will be grounded.
Thank you. Sorry I think I worded my question badly, I can’t see a bolt anywhere near the fusebox so I was wondering if anyone knew the location of a suitable bolt that’s accessible on the chassis? If I can’t find one would a strong adhesive conductive tape work do you think?
No !!
Unless your car is glued together, there will be bolts all over the place! :biggrin:  The dash itself is bolted in.  If you remove one of the plastic covers either side of the footwell, or part of the door trim, you will almost certainly find a suitable bolt.
This is a picture from my Mk3 Focus if that's any help.
😆 thanks a lot everyone! I can confirm my car isn’t glued together (or held with conductive tape…)
I found a bolt tucked away under the dash so grounded to that and everything’s working as it should!
Thanks again everyone 👍
