vacuum leak
hi all anyone had issue with vacuum leak on a fiesta 1.6 tdci now to resolve  please
What are the symptoms?
Vac leak can really only affect turbo boost control or brake servo on these.
Turbo diesel intake is generally under boost so they don't suffer the same running issues as NA petrols with a vac leak.
Jumping when 1st drive off. also at 50 to 60mpg it feels like it missing a beat
Sounds more like an injector fault to me.
new injector new egr valve new map and mass sensor new fuel pressure sensor and new boost pressure sensor plus full service
new injector new egr valve new map and mass sensor new fuel pressure sensor and new boost pressure sensor plus full service.  when 1st starts up runs and revs up fine when you pull away it feels like a air lock or something
Is that a full set of injectors or just one?
As you've changed so many parts, it's difficult to know where to look next. :sad:   It may even be a poor wiring connection that's getting moved as you pull away.
full set of new injectors
will a fordscan find the issue
Forscan should give us a fault code that can help find the issue.  I would recommend doing that if possible.
will it show any wiring faults
Yes.  It can detect open circuits and short circuits.
thanks for that Tom
