Glow plug relay module location
Having trouble starting in the colder mornings so need to check the relay and module
Mrs has moved my haynes manual so any help please
Fiesta mk7 1.6d 2009 rhd
Have you looked in the cupboard under the stairs ? 🤣
How did you no I have a cupboard under my stairs...what you trying to tell me
This question keeps coming up on here recently but either I'm missing the answers or they don't get posted.  I seem to remember the Haynes didn't help previous posters.
I thought it was mounted below the NS headlight on the Mk7, but perhaps not all of them.
Have removed both headlights and in engine compartment but it's still hiding..Will wait till weekend and remove belly pan and check underneath
I don't think it'll be underneath.  Relays are prone to damage from water and salt so they're generally kept higher up.  I think it'll be around the chassis leg near the battery & fusebox somewhere.
Thank you
Will have to have another good look
Also have a starting problem with starting and fuel
I have fitted a primer pump as the fuel drops back over night But not every night.
I see bubbles in the pumps clear pipe and have to prime most morning
Information I've seen on this subject gives 3 different answers with regards to the Glow Plug control on the Fiesta Mk7.  It seems during the production run, and also possibly depending which factory built them the location and type of control changed.
  • The most common is the auxiliary relay box mounted behind the left hand headlight (the right when looking at the front of the car). The box has the capacity to hold 4 relays but I've only ever known it to have 2. There is one relay for the radiator fan and one for the glow plugs. The headlight has to be removed to gain access.
  • After a few years of production the glow plug relay was moved to one that was fixed to a bracket on the side of the vehicle battery compartment.
  • Lastly before the Mk7.5 production ended the glow plugs were controlled by an electronic module (not a relay) and the location was moved back to near the front left hand headlight.
Thank unofix will check on them locations at weekend
Dan
My 2011 1.6d had the glow plug module on side of battery compartment. It was subject to a recall - I think owing to risk of water ingress? Not sure how much help that'll be to you tho Danny...
Thank to all for that info
Off work next week so it's going to rain when I'm going to work on my car......sorry about that
