Stutter at above 50mph +
Ford fiesta 1.6 tdci stuttering around 50mph +. any suggestion
Split turbo pipe is one possibility
do you mean the rubber ones
Hi, yes. The trouble with those pipes is that the thick rubber outer has a mesh inner lining which, if the outer rubber pipe splits (which it does with age and heat) tends to hold the split together, making it difficult to detect,  the split will open up under boost pressure, resulting in boost loss which causes the hesitation/stutter. That's in my experience anyway, and must reiterate that the split is difficult to detect!
