door help
some ones crunched my door in a car park.
my car is 2011 3 door model, just wondering if all mk7 doors are the same and will fit if i buy one from scrappy? 3 door version ovs.
threre's one off a zetec s looks exactly like mine.
noticed some have silver trim along the bottom of the window where mine has black rubber.
The door will physically fit, but will probably have the wrong modules & wiring unless it was from an identical spec car.  You may need to swap those over.
Chrome window scrapers were part of the Titanium trim I believe.  That can be swapped for your black ones.
thx tom
As Tom has said above, you would be well advised to transfer all wiring and modules from your original door over to the replacement. Leave the door card off the new door when you fit it. Then check that it locks and can be opened from both outside and inside before fitting the door card. There have been several instances of people replacing a door and closing it only to find it locked and could not be opened.
