crank timimg
hi any ideas, will turning the crank without the sensor in effect the starting of the vehicle. vehicle turning over but won't fire up.
If the PCM does not know that the Engine is turning then it is unlikely to do the necessary to enable the Engine to start.
Some Engines may be able to use a substitute signal from for example the Camshaft arrangement or even a Fuel Pump in the days when Distributer Pumps were used to provide a signal in some circumstances and the Engine may start in these circumstances.
If you bring up the RPM PID in FORScan and turn the Engine over you should see if any RPM's are being detected.
