crank sensor wiring
hi all anyone had issues with the plug connector and wiring from the crank sensor?
O wiring issues are common. Even slightly loose pins can cause havock. Continuity, load and resistance tests usually show up faults there. A pin drag test can also help identify a connection.
thanks for that the car is turning over but just won't firer up.?
