Park Pilot Malfunction
I have a 2017 Fiesta St-line and when I put it in reverse it now comes up with Park Pilot Malfunction and warning chime, most of, but not all of, the time.
Any thoughts as to the cause or how to fix it  thanks
Firstly check that you car battery State Of Charge is in excellent condition. Park Pilot does not like low battery conditions. You need to use a multimeter and measure the battery voltage across the terminals 1 hour after parking.
If the battery SOC is at least 70% then you will need to use FORScan to check for stored DTC's which will identify which sensor(s) are causing a problem.
Are all the sensor working ? if not give the battery a good charge as per Unofix
