new crank sensor fitted
new crank sensor fitted engine turns over but won't firer up ?
Any other faults before the change
Does attempt to fire
Try easy start..if it fires up atall then it's a fuel fault
Was it running prior to changing the crank sensor?
Have you read the codes to look for faults?
Yes
None does attempt to run with a sniff of easy start
Have you tried priming it until  bulb is solid
Ok, so it ran fine before you changed the crank sensor. Could be you've not pushed the sensor in far enough. So slacken it off, push it right down till it hits the flywheel then back it off 1 mm or so. Does it fire up now?
p.s. why did you change it?
Yeah tried thank. Even tried bump starting but no joy
 With a sniff of easy start it Runs for about 5 seconds then stops
the sensor doesn't push in. but it might have a mm or 2 movement will the crank need to be top dead centre before fitting the crank sensor
