Fiesta wheel offset question
I need to buy a new set of wheels for my 2013 1.6tdci fiesta tdci and i am not sure if the ones i found will fit
 Curently my car has the 175x65x14 tire on 5,5 x 14" 37.5 offset wheel .
I found  the exact same model just that this new wheels are 6 x 15" 37.5 offset . This wheels are form B-max model. On ford accesory website the same model of wheel  but for fiesta model is 47.5 offset .The tires are not a problem because i have the 195/60/r15 on the door sticker that will fit the new, bigger wheels
So simple question : will the 15" with the exact same offset with fit on my fiesta?Or should i look the 15" one with the 47.5 offset just like on ford website?
I hate offset questions.
I think the 37.5 ET will be 10mm further 'out' than the factory specified 47.5 ET
It may be fine, or the outer edge might catch the wheelarch.
And are you sure the B-max wheels have the same number of bolt holes that you need?
yes, they have the exact nr of bolt holes and the distance between them is exactly the same...I was more worried about the interior part if will affect the suspension by beeing to close the the parts or something.As for the exterior arch, i don;t think it will be a problem if it's a bit outside, it may look better..
