Fitting cruise control in '14 Zetec Fiesta 1.0 (nonecoboost)
Looking to add cruise control to my Zetec after seeing someone do it to their Zetec S on Youtube. I'm wondering if anyone has done this to their Zetec and in particular 80ps non turbo.
Installing it seems to be a piece of ***** assuming you know what you are doing: you only need to replace the steering wheel control with a cruise control one and connect it into the existing wiring block already there. and finally alter a setting through the OBD.
The only other thing to check is if your clock spring supports CC
You may need to change that too
You will need FORScan to turn on CC once hardware is installed
