Ford Fiesta 1.4 TDCI error Engine system fault and beeping
Hello, I have a Ford Fiesta 1.4 TDCI 2007 and I've noticed a problem while driving, where the exclamation mark and cog warning lights come on, accompanied by a beeping sound, and the instrument panel displays the message "Engine system fault." During diagnostics, an error related to the high-pressure sensor appeared. Can you provide more details about this issue? I can also attach a video recording.
Thanks a lot.
If you use the software FORScan for Ford diagnostic trouble codes it will provide you with more information.
FORScan: https://www.forscan.org/download.html
Connecting cable
vLinker FS: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
NOTE: A 2007 Fiesta is a Mk6.5 in the UK (not a Mk5)
Thanks for this i will check that. I send simillar problem and sound like my car.
