Fiesta mk8 2019 ford performance
Hello
I reset my modules by accident and lost the my view performance digital display.
Does anyone know how I can get it back? Splash screen is fine.
I don't have IPC module showing on my list?
I wonder if this is because of a fault BCM? I have gained a air bag fault for no reason that won't clear and it suggests
Code: U0423 - Invalid Data Received from Instrument Panel Cluster Control Module Additional Fault Symptom (:81): - Invalid Serial Data Received Status (-8B): DTC Present at Time of Request Malfunction Indicator Lamp is On for this DTC Freeze Frame #1: -EVENT_TIME: 160674516 s (Fri May 17 14:05:52 2024) - Event time -TOTAL DISTANCE: 53564 km - Total Distance -8B -OA -08 Module: Restraint Control Module -0A -0A 6-0A 5-0A 5-0A 5-0A Freeze Frame #2: -EVENT_TIME: 160674516 s (Fri May 17 14:05:52 2024) - Event time -TOTAL DISTANCE: 53564 km - Total Distance
Connect again but don't load saved profile, see if it shows up
Hello mate I have tried this several times IPC doesn't come up.
Is the IPC working?
