1.6 TDCi Clutch Adjustment HELP!
I apologise as I am not too sure what to look for and finding conflicting information online.
I have a 2011 Ford Fiesta Zetec S 1.6 TDCi 95hp, my clutch pedal bit point has gradually shifted higher up, I am wondering if anyone knows if there is any adjustment and if this will be cable or hydraulic?
I'd suspect that the clutch is wearing out and now disengages with just a little pressure applied to the pedal
The clutch is hydraulic.
Not sure if it's the same but I have a 2009 1.6d and it is cable..there is a small adjustment at the clutch end behind the plastic cover passanger side underneath...just remember the original settings though
Would you mind sending me the reg or VIN via PM?  I can't recall seeing a cable on any Mk7 Fiesta.
I suspect that there is a degree of confusion here. All versions of the Mk7 Fiesta with a manual gearbox have a hydraulic operated clutch, not cable.
There are two gear change cables from the gear stick that run to the gearbox, both of which are adjustable.
You are correct unofix..I totally misunderstood the question..and it's not the 1st of April
