Mk7 Ford fiesta zetec s 90 tdci
How much transmission fluid and where is fill and empty on mk7 Ford fiesta zetec s 90 1.6 tdci 09 plate
From memory
Undo fill plug first..passanger side at the front behind plastic panel..hex socket
Fill is passanger side near where drive shaft goes into gearbox..you can see it through the passanger wheel well..I used a fuel with pipe down behind the battery then into fill hole
Amount is until it spills from the hole..just under 2 litres from memory
Important
UNDO FILL PLUG FIRST BEFORE DRAIN PLUG
This was on a 2009 1.6d mk7
