fiest mk6 relays
so my car has suffered electricals issues such as odometer freezing, mileage prediction failing, engine management light, abs light and speedo not working. when i removed relays r6 and r11 the problems went away. but obviously i cant drive the car without them cause it wont start, can anyone tell me what to do next. PLEASE
Hello Charlie, pleased you made it to the Fiesta forum.
The most likely cause of the problems is a faulty ABS speed sensor on one of the wheels.
If you use a laptop running windows and the software FORScan (free) it will tell you what the issue is and if it is the ABS wheel sensor it will tell you which wheel it is.
You will need a vLinker FS connection cable which can be bought from the likes of Amazon for about £28
