Ford Fiesta mk 7 2010 Rear Springs Replacement
Hi There,
              Advisory on Ford Fiesta 2010/ 2011 1.25 engine had corrosion on rear n/s spring
              on both ends full coil ring length around. Also in the middle about 2cm to 3cm length
           so decided to replace both springs. So put rear wheels 75mm high on ramp stand then
          handbrake on and in reverse gear chocked front wheels. Then jacked up both sides of rear
           body at jacking points so wheels were off ramp stand, Then doing one spring at a time
           undid bolt securing shock absorber but before removing bolt put jack under shock
          absorber bracket jacked so it just gripped. Then removed bolt and let down jack then got
          person to stand on top of tyre wheel to allow spring to be easily be removed, Checked top
          and bottom spacer pad rings (Top rubber Bottom plastic) make sure these go back in right position.
        Top rubber has protruding rubber prong to fit into small hole and bottom plastic spacer
        Has arrow cutout facing forward and clip at back to into small hole. Best method is put
        all together then place into position (getting someone to stand on wheel again),
       Then place jack under shock absorber bracket point and jack up until holes line up.
       Reinsert bolt with Loctite added to threads and tighten up to torque spec remove
      Jack now other side to do, when both sides done lower car down onto ramp stand
       and take for test drive.
