Fiesta led swap
Hi everyone,
Does anyone know if changing my original rear lights to the nicer ones with the LED side lights is simply plug and play, or do i need something else?
My 2015 Titanium X didn’t come with them and i think they look much better so i was considering replacing them…
Cheers
25 minutes ago, oliverlesauvage said:
Does anyone know if changing my original headlights to the nicer LED side light ones is simply plug and play, or do i need something else?
I'm confused. You ask about, 'headlights' and then show photos of rear light cluster?
Sorry that was a mistake i meant rear lights/ tail lights. Will edit that now
If he's driving everywhere in reverse, that could explain the poor mpg! :tongue:
The wiring harness connectors will be different. You will also need to use FORScan and change the settings in the BCM from the standard filament lamps to the replacement  LED or you will get constant lamp failure warnings.
