Fiesta 09 mk7 zetec s tdci 1.6 won't start or crank
Hi, my fiesta 2009 fiesta 1.6 tdci won't start. You turn the key and the lights in the dash will lit as always not dimmed lights because of the battery, battery is fully charged but when you turn the key won't crank not even make a noise like when the starter is on the way out. What can possibly be? Ignition switch maybe?
Could be a few things
Do you hear a click from the starter motor..if not check starter relay and starter fuse in fuse box beside battery first
No click and relay is fine i suspect the solenoid?
Twice I had bad terminal on the solenoid..had to disconnect pos on battery..disconnect terminal on solenoid and wire brush all 3 terminals..not a great deal of room but worked at the time..up on ramps..bottom engine cover and small hands
If the starter has died then it can be done from the bottom without removing drive shaft but is very tight..I mean very tight..video on youtube
