Mk7 fiesta zetec s 90 tdci
My mk7 fiesta zetec s 90 tdci started then cut out now won't restart again been having rough idle and cutting out on me when warm now this car is doing my head in
Try easy start..if it starts then it's a fuel problem..first thing to check
I have tried jump leads and bump starting nothing
If there is air in the pipes then it won't.. try easy start..if it does splutter or start up quickly its a fuel problem..if it doesn't its an electrical fault
When the ignition is on full has the red immobiliser light turned off
No The red light is off
Easy start 1st
Can pretty much rule out battery & starter if it won't bump or jump.  I also suspect a fuel issue.
If you don't have any EasyStart you can use a bit of deodorant instead.  (Not roll on though. :wink: )  Pull off the turbo intake and spray it directly in there.  It just gets stuck in the filter if you do it further back.
Could also be the crank sensor.  I take it you don't have access to Forscan?
Yea but I don't have no codes coming up
Where is the crank sensor on this car
Under the crank pulley, bottom of the aux belt.
When took out dose the crank need locking to refit
No.  Don't need to unbolt or remove belt.  The sensor just slips in behind.  Be careful pulling it out though, the sensor wheel can be damaged if you just yank on the sensor.
Ok thanks
All sorted out car is running now it was start relay that's for helping me out 👍
