map sensor. 2012 1.6 ti-vct
hi all i have a mk3 ti-vct 1.6  which is running a little rich, my cheap scanner shows the map sensor reading of 99kps all the time, what ever the driving conditions or revs. thinking this is the problem but it doesn't seem to be on the inlet manifold, or if it is i cant see it. any help would be appreciated.
Get rid of that Cheap scanner. Download onto a laptop a copy of Forscan.  It's as damn close to what Ford use themselves.
Search on this forum for Forscan. Within you'll find how to use it, where to get it and what OBD lead you need.
Cheap scanners are exactly that. CHEAP szhitt.
thank you for your input, as worthless and rude as it was. i take it you dont know where the map sensor is located?
thats a bit strong aint it. he basically gave you the info you needed to the letter and you fling that at him 🤷‍♂️ his advice in my opinion was 100% on the money
If anyone can tell you where it is it will be @TomsFocus
For your own benefit you would be wise to use FORScan, as it will give you the full Ford specific DTC's that even very expensive code readers can't. Below is a post giving the 3 options on how to connect
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
The 1.6 Ti-VCT doesn't have a MAP sensor fitted at this age.
......and that would be the reason that the OP can't find it 👍
Thanks Tom for clearing this up.
