Keyless remote antenna.
Please can anybody tell me where the keyless remote antenna is on my 2014 ford focus titanium?
I'm sure the remote receiver is built into the BCM
Aren't there multiple keyless antennas across the vehicle - one at each door handle, the boot, and the blanking plate where a traditional key barrel would normally be?
The keyless system detects when the keys are anywhere in the car and enables the sensors/buttons on the door handle if the key is close enough - the system can also tell if you've locked the car and try to shut your key in the boot...
ok ive just removed my RF antenna from my car because my keyless entry and start failed. See my post, Key not detected. My Rf antenna was above the mirror area. You need to remove the sunvisor and your overhead light to gain access to it. Its glued onto the head liner using hot glue. Reach up and feel for it by pulling the liner down at the windscreen and reach up for it. Unplug and remove. £75-£80 for a new one from ford. You need the light out to unplug it. There is also an amplifier in the boot floor, this is to allow you to open the doors with remote while at the rear of the car. Hope that helps you.
  • 1 year later...
Hi, I have the same issue on a 2016 Ford Focus Titanium X, do you know the part number for the RFA?
