Focus door hinge
Hi guys
My focus MK2 for passenger's door hinge bolt broke in two halves and the hinge is ok tho. I got spare bolt from fords for 3 quid. The half that broke inside the passengers wing side how the hell can I get that half out.  I tried a dremal to make a slot and turn it with screwdriver that made things worse as it's got further back into the wing.
Every time u open the passenger you door you got hold it tight I'm hoping not for windy day.
Cheers guys
Does anyone know how this is done a broken bolt on focus mk2
Thanks guys
Don't know how you access the broken hole bit on the right
Weld nut has detached from body
Good luck😬
Probably better off, with the age of the car, removing the check arm completely and manage the door opening yourself when you have a passenger
Yeah that's what I have been doing telling passengers door broken and holding it when they have shopping.
Oh thread on right is welded on, I thought just was like a bolted on from rear part. I got wheel lining out and the gloves box.
I'm thinking about getting the left bracket welded just on to the hole area or I see u can buy them butterfly bolt thing which spring open inside.
Cheers guys
Good luck😬
You are no doubt correct, though my OCD couldn't cope with that, I'd have to find a way to properly fix it! 😁
Cheers guys
You won't get into that panel.
Yes you could weld on a 2nd hand check arm, I wouldn't risk welding that one, if it's been stressed it will break, then you have to get it off
The proper fix for that would be cutting a square hole in the pillar.  Welding the nut back on.  Then welding the square back in.
Finding a bodge is the more realistic option.  You can buy universal soft material check straps online.  Usually used for van doors but as long as you get the right length should work for a car as well.  Just need a couple of self-tapping screws each side.
You can't, not without cutting holes in the bodywork.
I'd drill the hole out using a 10mm drill bit, and then fit a 'nutsert' or 'rivnut' (other brands are available)
Thanks to everyone.
Where do I get the bits from to fix it.
I would leave it but someone will not hold the door and it fly off
Just use Google
Example:
And can anyone please post any links where to buy then from,
thanks guys
What about screwfix
Will this do the job
Or what are these
Thanks guys
No.
How does nutsert work u put in hole and lip will stop it falling through, but when the bolt goes into it ain't the nutsert going to spin
If you take it to a decent body shop, they will install a rivnut for you so you can bolt the check strap back to the body.
Good suggestion @TomsFocus, I never thought of that👍
Not my suggestion, but thanks anyway. :wink:
In the picture it looks like the nut is still partially there.  That'll have to be fully broken off to fit a nutsert and will rattle at the bottom forever.  That is probably the cheapest option though.
Funny, when my 'checkstrap' broke I suggested that from the factory, they should be held on external fittings rather than the way they do it LOL
Went to a body work shop they said to do it properly would cost around 600 pound.
Does anyone know the thread size on bolt. Looking at them nutsert things
M6 I believe
Drill out A-Post, insert an M6 rivnut, fit bolt
It's just getting the rivnut properly installed you'll need help with, unless you buy a manual hand tool
Couldn't believe the price of the garage 600 quid.
Here bit better pic
What u think
The whole hole from side to side is 14mm, not measuring the broken lip thing
As u can see it's bent down inside and don't think a rivnut/nutsert going to grip.
I looked at these things but not sure
