Battery
Hi all,
I have a fiesta ecoboost 123 on a 64 plate which needs a new battery. Any recommendations would be welcomed.
Dicko.
Got mine from Halfords (own brand) and it's been absolutely fine. Always bought from there as they seem to last a very long time.
Halfords don't make batteries btw.  They're just rebranded Yuasa batteries.  Which is also the brand most recommended on here nowadays. :smile:
Thanks for the replies. Can you remember how much it cost?
Dicko
https://www.tayna.co.uk/
YBX5075 Yuasa Silver High Performance Car Battery 12V 60Ah HSB075
Thanks.
That's half the price of batteries I've seen!
Dicko
Any ideas if this battery OK for stop/start.
Cheers
Dicko
I assume that this symbol on the Tayna web site means that it is not.
Need the EFB version for stop/start.
Thanks.
I take it that's why that battery is half rhe price of batteries I've been quoted?
Cheers
Dicko
The EFB battery should be less than £100. @unofix do you know which stop/start battery fits a 2014 Fiesta Zetec S EcoBoost 125 please?
27 minutes ago, Dicko01 said:
Thanks.
Cheers
Dicko
As above, should still be under £100.  I don't know the dimensions for Fiesta so can't commit to an exact Yuasa part number myself.
At halfords site I just keyed in my reg and this is what it come up with.
ThanksScreenshot_20250914_153812_Chrome.thumb.jpg.92ca0460bff540586f2828f8dbc2267b.jpg
What do you get if you put your reg in here? https://www.tayna.co.uk/
If it gives you a choice of batteries then select the Yuasa one.
Edit to add:
Its probably going to be this one, but I don't know your registration number so I can't take responsibility if I have it wrong:
https://www.tayna.co.uk/car-batteries/yuasa/ybx7027/
£90.57 delivered.
Edit to add:
£90.57 delivered.
This is what I get.
You need the YBX7027 for Stop/Start.
Well unofix and I both picked the same battery independently so I recon you should be good to go. 😀
The dimensions of the battery are different, the height of my battery is 174 mm rather than 190 mm. The negative lead would reach but the positive lead would be a problem as it is rather tight as it is.
Dicko.
16mm difference, I would be very surprised if there is not enough play in the cables to fit that. I'm not going out to look at my Fiesta today as its absolutely hissing down here at the moment.
Yes about 1/2 inch difference and it is listed as the battery for diesel Fiesta's.
Having just checked a few random registrations of similar age and specification Fiesta's found on AutoTrader, the battery is listed as fitting. The height measurement of batteries is often misleading, some measure just to the terminal post, and others to the very top of the case.
The equivalent to the Halfords one is YBX7100.
https://www.tayna.co.uk/car-batteries/yuasa/ybx7100/
Thanks for everyone's input, much appreciated.
Dicko
Let us know which one you go for and how you get on with it please, it will help others in the same situation.
Hi all,
I got in touch with tanya and ask for their advice on which battery I needed thus is what they suggested.
After sending the dimensions and pictures of my current battery they recommended this.
Screenshot_20250915_150345_SamsungInternet.thumb.jpg.a200ec90ffbf1a27b0b503cc530f53ca.jpg
It's the exact same dimensions, so I've ordered it and it should arrive within 2/3 days. So fingers crossed its suitable.
Chris.
I bought a similar Exide battery nearly 4 years ago.  Sat in a car boot for 3 years.  Fitted this year and still going well.  So my personal experience is that Exide make a decent battery. :smile:
