2011 titanium 1.6 petrol drivers door wing mirror fault
sometimes my wing mirror doesnt open out when swilching on the ignition, sometimes it does. When it doesnt open out I press the button by the window controls sometimes it works sometimes not. If this fails, I open my drivers door windon and then press the mirror button which always works.? Is there a remedy for this as its driving me nuts. Thanks in advance.
As it's only one mirror that rules out a control fault.
It is possible the motor is just worn out after 15 years.
Alternatively there could be a broken wire or a corroded plug around the drivers door.
Cheers Tomsfocus, for your valuable information, I will check it out when the weather gets a bit warmer.
On 3/16/2026 at 2:41 PM, TomsFocus said:
