Battery dead so cannot open door
12v Battery dead over night.
You can open the driver's door with the key then lean across to bonnet handle.
On sone of these you can pull the handle far enough back without opening the passenger door. Though officially you are meant to remove the bonnet lever and then use a socket to turn the cable holder underneath.
This may have just been caused by a random glitch with a module staying awake. It happened on my 2021 Active only once during 2 years of ownership. I did not replace the battery, just jump started and ran for a while to recharge it.
