P06DA error code oil pressure solenoid
Hi, I've had an engine management light come up on my 1.5 tdci focus after some dpf issues. I've managed to sort the dpf issues out, but I'm struggling to find online where this solenoid is to begin diagnosing this error. Does anyone know if this is in the oil pump, and if so if its accessible without removing it.
Cheers,
Solved by TomsFocus
  • Solution
Hi,
The solenoid is on the oil pump. And it can be swapped without the removing the pump. There were two different pumps fitted to these, one with a solenoid and one without. If you haven't been able to locate the solenoid, I'm wondering whether that code is a red herring in your case.
Genuine Ford Oil Pump Drive 2093005 | eBay UK
Finally got a chance to look at this today, yeah it seems you were right about the oil pump being one without it. Weirdly there looks like a connector coming off the loom just above the oil pump.
Took it for a long drive this evening and the light went off, and no more error code. Thanks for your help!
