Fiesta Finesse Burning Oil How Much Is Acceptable
Hello
My g/f's 1.25 Finesse is losing oil.
We did a trip from north wales to st austell in cornwall and it used 2.5 litres of oil in 300 miles.
When the car is standing there is no oil under the car.
We have not noticed blue smoke as well.
The car has done 63500 miles and is a 2004 54 plate
Jamie
Hello
Jamie
Something drastically wrong there mate.
I would expect a modest top up afetr 1000 miles if that, but there is soemthing wrong there.
How much smoke is coming from the exhaust when its running? If there's none dripping, and none visible in the engibe bay, the car is burning oil.
I wouldn't drive it while its like that if it was me mate, it could seize
Hello
Jamie
jamie that is a serious amount of oil to use over 300 miles, if there are no obovious signs of an external leak, then take out the spark plugs. if they are black and sooty then the oil is being burt in the cylinders. not good, either the valve seals are leaking or the piston rings are going, at 63500 miles however, i would not like to think that they are worn out. a simple compression check on each cylinder will confirm if the cylinders are holding compression, ie not leaking and allowing oil to the spark plugs. i would double check under the car to try and see if there are any leaks, is the oil level being maintained at the correct level,check it, as if you overfill the engine it will pump it out via gaskets,seals etc hope this helps.
Hi
Thankyou for the reply
taffg you quoted my message but didnt say anything ?
We will be on the look out for blue smoke from now on
~Jamie
Hi
~Jamie
hi jamie, i did reply to your post and i see my comments posted, however i will try again,
