"taking Oval To Blue Horizon" Lenny's Build Thread 2010-2015
Damn you Lenny. Just read through your whole thread again, now you've got me bidding on PS2s !!!
Sent from my iPhone 5s.
:lol: my bad
Just to add the Tv tuner has an RCA input with 3 video outputs,
Makes it easier to install dual items because the Playstation comes in on the TV's AV input
Then the video outputs can be sent to three different screens displaying both TV stations and the Playstation.
I recommend the joypad extension cables aswell mate,
This allows permanent plug in to the playstation2
Then a socket is fitted under the drivers and passenger seats,
Plug in joypad when required :)
There linked in a previous page mate.
Also recommend the WiFi Router,
Gives the car its very own WiFi HotSpot :)
Great for streaming Spotifi without affecting your monthly data allowance,
Some cars have Twin Turbo's mines got 4G
  • Replies 1.4k
  • Views 434.2k
  • He's toothless, wrinkled, smells of wee and has a breast fixation (but enough about Lenny ;) )
  • Update, As previously discussed in the build thread on page: 74 Link: http://www.fordownersclub.com/forums/topic/41443-taking-oval-to-blue-horizon-lennys-build-thread-2010-2015/?p=452215 I have had
  • Been at the car today from 9am to 19:00 Had to drive with only drivers seat installed to local DIY store 😀 Bit faster with no interior or door cards fitted, had to purchase some more bolts as previ
Man, you are dangerous lol.
I was just going to have the ps in the glove box all connected up then have the power connected to the 12v in the arm rest.
Obviously only plugged in when I need it. Just flip the glove box down when i want to play.
Might look at those controller extenders.
Hey Lenny .. I'm looking at buying the same radio as you. Only just noticed re-reading the thread its the one I want. Been looking for an android auto one.
Only thing is yours doesn't seem to meet the surrounding bezel.. Is this the case or camera shot? Also have you wired up the stem controls?
Sounds good mate, that would be tidy and only live when you want it to be while retaining stealth stock appearance.
Get yourself GranTurismo 4 as it has the Mk2 Focus in the game :)
Drive a focus in your focus,
Here's the seller of the joypad extensions link: http://www.ebay.ie/itm/191002378266
Thanks mate,
Its a Pioneer AVH-8600BT
i had the surround off in a few photos as i had just been removing the headunit,
See fitting guide here for finished item pictures:
http://www.fordownersclub.com/forums/topic/63689-guide-fitting-aftermarket-headunit-mk25-focus-2008-2011/
I've also got the self calibrating mic,
If you would like a loan of it to best calibrate your equaliser settings once installed in your focus as its not somthing you would use very often.
Cheapest supplier of the headunit was Dynamic Sounds in London a staggering 250 euro cheaper than Halfords Ireland last November lol
I probably will buddy. It is either one of these of one of the new AVIC series .. Depends how much bonus I get from work so see how it goes, if its as good as work make out I'll go for an AVIC.
Was the stem hard to wire in?
I've got some of the NFS games already and my favourite, Half-Life. I'll pick up GT4 in my local Cex probably for 50p lol
No was alot easier than it looks mate,
I purchased the full conversion kit from dynamic sounds which came with a steering stalk adaptor and the iso block cable,
I later removed the iso block and hard wired the system using male and female crimp spades,
I done this to reduce bulk at rear of the headunit as ive got 13 RCA plugs in there aswell as three USB connections and the regular cables.
Best way to hard wire is to plug in the iso block that comes with the kit,
Then one by one,
Snip a cable then its corrisponding mate on the opposite side,
Put female spades on the car loom side
And male spades on the headunit side.
When done should look somthing like this :lol:
No big plastic box
Eliminated all of this from rear of headunit:
Haynes manual also helped diagnose cables feeding to front and rear speakers as i cut them here and spliced in feeds from the amplifier to the speakers,
Then run a feed from the headunit front speaker output to a plug in th3 boot,
So when amplifier panel is removed i can plug speakers in to this feed to continue listening via the headunits internal 50w supply.
+1 isn't it mad to see games like that going so cheap now,
Yet back nine years ago people were queuing outside of GameStop at 1am paying 60 quid to get it having put there name down six months previous,
Makes ya wonder Whats it all about.
I'm big fan of the Need For Speed
I have 1,2,3 and Most Wanted thanks to Jamie (JC600) only one im missing is "Black Edition"
Gotta love the dump valve tone lol sounds better than the diesel,
Progress Update:
I've completed the rear De-Wiper mod on the focus and created Guide here:
http://www.fordownersclub.com/forums/topic/70383-guide-de-wiper-ford-focus-mk2-mk25-rear-wiper-removal/page-1#entry483277
Pretty happy with results,
IMG_20150626_092805_zps3hc0qksr_edit_143
While i had the inner boot panel removed i took the opportunity to fit the SPARCO Tow strap as a boot grab handle today aswell,
see fitting Guide for this item:
http://www.fordownersclub.com/forums/topic/70382-guide-fitting-boot-door-tow-strap-ford-focus-mk2-mk25/?p=482009
IMG_20150806_154250_zpsapxdb4wd_edit_143
Short Video of TV Tuner function is now on YouTube:
https://youtu.be/reTdJA0XOjM
Does the steering controls work with this head unit>?
Hi mate,
Yeah an Connects2 aftermarket convertor comes with the aftermarket headunit conversion kit from DynamicSounds,
It continues to retain full functionality,
However in the case of the TV tuner; this is not built in to the headunit,
The headunit acts as a monitor in this case and only the volume can be controlled via the steering stalk control,
All other commands are via Xtrons Supplied TV remote,
IMG_20150322_085515_zpstrbtwbfe_edit_142
The steering stalk control even works to allow skipping of music when streaming YouTube from phone via Bluetooth or Spotify via Bluetooth,
The mode button also cycles through the various source buttons.
The picture quality and the speed of the TV tuner is impressive Lenny. Reckon it would keep everyone entertained on longer journeys. Nicely done buddy :)
Vicki Finished painting kitchen what i call "RS Green" yesterday,
So today i thought the RS500 canvas would be good contrast :lol:
Woke up at 6am heard the focus engine revving,
Went out and saw my son :lol:
IMG_20150521_170311_zpsyi10zlnq_edit_143
lol :D
That's adorable! You are lucky he didn't go for a joyride :P
How are you finding the signal strength from the wifi Leonard mate?
Its a mod I'm definitely gonna do on the mondeo.
I'm dubious about the 4G claim though, as I've currently been paying an extra 2quid a month for 4G on my samsung and I honestly don't think I've experienced any '4G' speeds in the 5 or so months I've been paying for it. I'd compare my mobile data speed to dial-up at best. Complete pants. Not as if I'm anywhere rural either so what I'm paying extra for I really do not know :(
Although the router is capable of 4G and is sold as a 4G router I've not got a 4G contract its a 3G bill pay broadband sim I'm operating in it, so i cant comment on the 4G comparison to its predecessor as of yet however it rarely freezes to buffer video streams.
The coverage it picks up is very good and the WiFi signal it broadcasts is receivable within the front of the house when car is in the driveway.
The router has the same WEP key security access as an in house router too, it doesn't have to be free to all I've got mine secured with wep key.
The car wifi routers are not available in Ireland yet neither I've bought mine unlocked from ebay uk and shipped it in via parcel motel.
Id definitely recommend it mate has saved me a lot on phone bill around 30 euro per month saved as i no longer exceed my monthly 1Gb of data allowance when streaming Spotify or YouTube in the car.
IMG_20150602_185733_zpsxvohe2cs_edit_143
IMG_20150602_185741_zpsfqu2dhyh_edit_143
Lovin this tune
DJ S.K.T - Take Me Away
When listening in the car the gaps in base gives real dimension to the speakers,
Ive set crossovers to
Front Speakers 100hz high pass
Rear Speakers 200hz high pass
Sub 50hz low pass
Lovin this tune listening in the car the gaps in base gives real dimension to the speakers,
Front 100hz high pass
Rear 200hz high pass
Sub 50hz low pass
DJ S.K.T - Take Me Away (Ft. Rae): https://youtu.be/JP_thHzKcIA [/quote
Lenny if you're setting the high pass to 100hz & the low pass to 50 then what's producing 50 to 100hz? Do you just have a gap?
From my understanding at present mate, ive still gotta research :lol:
Its anything above the set level doesn't sound from the set location,
So anything above 50hz doesn't go to the sub,
Anything above 100hz doesn't play in the front
And up to 200hz plays in the rear
All comes together
High pass filter is it plays anything above the set frequency.
Low pass filter plays anything below the set frequency.
So you've set it so anything below 50hz goes to the Sub, anything higher than 100hz goes to the front and anything higher than 200hz goes to the rear.
You'll still get all frequencies in all speakers but certain frequencies will be really attenuated in accordance with the filters
Ah sod it :lol: ive set it back to auto setting until i research it,
Too many options mate
Haha! There is indeed! I got one of the sound engineers from work to set mine up ;)
Ledgend! B)
Ive used the Pioneer calibration mic. But was trying to further build on that,
I want to have lowest sound coming from the front speakers so everything is built up from the rear to the front
